The redevelopment of the Waldorf Astoria New York represents a comprehensive structural rehabilitation and adaptive reuse of one of New York City’s most iconic historic buildings. Originally opened in 1931, the Waldorf Astoria occupies an entire city block in midtown Manhattan, bounded by Park Avenue, Lexington Avenue, East 49th Street, and East 50th Street. Rising 44 stories above grade with an additional nine pinnacle levels, the building encompasses approximately 1.6 million square feet. Before its closure for redevelopment in 2017, it operated as one of the world’s most recognizable luxury hotels with more than 1,400 guest rooms. The redevelopment transformed the property into a mixed-use building containing a 375 key luxury hotel, 372 condominium residences, and publicly accessible event and retail spaces. The project required extensive structural investigation, repair, and modification while preserving the building’s historic architectural character and accommodating modern building standards. The hotel reopened in July 2025.
The design team was led by architect Skidmore, Owings & Merrill (SOM), with structural engineering provided by TYLin (formerly Silman), and MEP and Fire Protection services were provided by Stantec. Construction management for the core and shell scope was provided by AECOM Tishman and Suffolk Construction, and construction management for the fit-out scope was provided by Suffolk Construction. Design work for the project commenced in 2016. The building’s exterior was landmarked in 1993, and several public interior spaces were landmarked in 2017. The renovation had to be completed while landmark areas were protected. Any intervention to the building that could potentially impact the exterior or interior appearance of the building were reviewed by the NYC Landmarks Preservation Commission prior to construction. While the upper floors of the building are now private residences, the public hotel areas remain accessible to all as they have been since the hotel opened in 1931.
Understanding the Existing Building
An early focus of the project was to understand the existing conditions of the building structure. Available documents included original structural and architectural drawings, original steel shop fabrication drawings, recent architectural drawings, Facade Inspection and Safety Program (FISP) reports, and documentation of related facade repairs. However, records of the many structural interventions over the years were not preserved.
The Waldorf sits directly above the Metro-North railyard just north of Grand Central Terminal. During the redevelopment of this area in the early 20th century, the open-air railroad tracks were lowered below grade and covered to permit urban development above. As a result, approximately 80 percent of the building’s columns extend through active tracks and platforms below. This condition would later influence construction planning and execution.
The structure is founded on rock using steel grillage foundations. Historical drawings suggest that vibration isolation from the rail operations was a concern during the original design. The foundation assembly incorporated a vibration mat constructed of sheet lead and asbestos between the steel grillage beams and concrete footings. While these materials would never be used today, they demonstrated the original designers’ efforts to minimize vibration transmission from nearby rail operations. This appeared to have been successful, as vibrations from rail operations has not historically been an issue for the building.
The building’s superstructure consists of a steel frame with semi-rigid partially retrained beam-to-column moment connections that provide lateral stability. As with many buildings of this vintage, a substantial amount of lateral stability is also provided by the stiff multi-wythe brick masonry exterior walls surrounding the perimeter of the building. Two primary floor systems were used throughout the building: draped mesh one-way slabs and two-way slag block slabs. Interior bays utilize draped mesh concrete slabs spanning in one direction, while perimeter bays employ a slag block floor system that functions similarly to a modern waffle slab. The slag block slabs typically align with the column free layout required within the hotel room spaces, whereas the draped mesh slabs were typically used in the corridors, at the roof, and in locations where the live load of the existing slab was higher than the 40 psf used for hotel rooms. While the slag block slabs were built using stone concrete, the draped mesh slabs used a combination of cinder concrete in some locations, and stone concrete in others. Understanding the material properties, behavior, and condition of these historic slab systems became essential to the redevelopment effort.
Investigation, Assessment and Materials Testing
Recognizing that successful renovation depended on understanding existing conditions, the project team conducted a comprehensive investigation program. Existing documentation was reviewed. However, significant gaps remained regarding modifications performed throughout the building’s operational history.
To address these uncertainties, selected floors underwent soft demolition early in the design phase. The 12th and 24th floors were chosen as representative samples. This process allowed the team to observe concealed structural elements, evaluate deterioration, and compare actual conditions with historical drawings.
The investigation quickly revealed conditions that would not have been identified through document review alone. One notable discovery involved holes in the structural slab below the bathtubs of the hotel. During a prior renovation, workers had cut large openings through floor slab to install new plumbing fixtures and piping. This condition was repeated at each bathroom for each of the approximately 1,400 rooms. These openings varied in size and condition, creating the need for substantial structural repairs. The strategy to correct these conditions was either to replace large areas of slab or a patching approach depending on the specific condition.
Material testing played a critical role in the project. Concrete cores provided information about material composition, strength, and undocumented renovations. In some areas, previous construction projects had added layers of concrete without adequate documentation. Understanding these modifications informed decisions regarding removal, strengthening, and load capacity of the existing structure.
Additional investigative efforts included steel coupon testing to determine material strength and composition, reinforcement testing of slab systems, and numerous beam connection probes throughout the building. As demolition progressed and new areas became accessible, investigation continued, allowing our team to refine designs based on actual conditions.
The team developed repair strategies that balanced structural performance, sustainability, and cost. Rather than replacing large portions of floor systems, the team sought to preserve as much existing construction as possible, and patch larger areas of slab than the typical 18 inches x18 inches patching threshold. An extensive load testing program was developed to verify that repaired areas could safely support design loads, in accordance with the NYC Building Code procedures. Plan B Engineering conducted the testing using a series of 50-pound steel weights to distribute the loading across the test area. Results were measured using strain gauges, deflection monitoring, and visual observations and demonstrated that properly designed and installed repair methods could successfully restore structural capacity.
To quantify deterioration and repair requirements, the specialty repair contractor Pullman was contracted by the owner to perform detailed floor-by-floor surveys after soft demolition. A systematic classification system was developed to categorize deficiencies such as small openings, exposed reinforcement, spalled concrete, damaged fireproofing, and cut reinforcing steel. Each deficiency category corresponded to a repair type which the construction manager used to estimate costs, schedules, and construction resources accurately.
Because modern mechanical and architectural systems would require numerous anchors installed into historic concrete, extensive anchor pull-out and shear testing was performed. These tests established the capacities of anchors installed in the building’s archaic slab systems and informed the design of suspended mechanical supports and other attachments. The pull tests were not pulled to failure but rather to the loading anticipated for light weight ceilings, electrical and mechanical equipment. Heavy mechanical loading was hung directly from the steel beams. The factor of safety of 5 was used on the anchor tests, and several different types of anchors were tested for the slag block and draped mesh construction. The investigations after soft demolition also identified areas of significant structural deterioration. Water infiltration through breaches in waterproofing had damaged portions of the north foundation sidewalk vault wall over the years, causing rebar corrosion and concrete deterioration. Similar issues were discovered at several facade locations, particularly near building setbacks and rooftop parapets where waterproofing failures had caused severe corrosion of embedded structural steel draped mesh.
Pinnacle Conversion and Restoration
One of the project’s most challenging scopes involved the building’s iconic pinnacles. These architectural features crown the structure more than 600 feet above the street and are among the building’s most recognizable elements.
Contrary to what many might expect, the pinnacles were never occupied hotel spaces. Instead, they housed mechanical equipment and fan rooms. Decorative stone screens incorporated into the pinnacles served functional purposes by allowing air intake for mechanical systems.
The redevelopment plan called for the conversion of these spaces into penthouse residential units. Achieving this goal required substantial structural modifications, including floor removals, new elevators, communicating stairs and upgraded building envelope systems to allow for this interior space to be fully conditioned.
Initial investigations, which were limited to the lower floors of the pinnacle and probing from the interior of the space for logistics reasons, revealed deterioration. Water had been infiltrating the exterior masonry walls, corroding embedded steel framing and weakening the masonry walls. Probing identified three-wythe masonry walls backed by terra cotta partitions. In select probed areas, the team found cracked bricks, deteriorated mortar, efflorescence, and corrosion of the steel. Structural analysis of the original steel structure revealed that the masonry walls contributed significantly to lateral stability of the existing pinnacles. This finding complicated repair planning because removal of deteriorated masonry walls could compromise structural stability in the temporary condition. The original repair approach involved localized repairs to masonry and embedded steel while preserving most of the existing construction, including the iconic copper caps. Once construction commenced, it became evident that the existing conditions were dramatically worse than anticipated from the initial investigations. Severe section loss was discovered in steel columns, beams, and their connections on multiple floors and in both pinnacles. Localized repairs would not be sufficient.
The project team ultimately developed a comprehensive reconstruction strategy. Various alternatives were evaluated, and in the end, the selected solution was to rebuild the pinnacle walls using a cavity wall system. The cavity wall comprised a reinforced and grouted CMU backup wall, an air gap, and brick masonry outer wythe wall around the perimeter built to the underside of the existing copper caps. This approach improved both structural and thermal performance while maintaining the building’s historic appearance.
Reconstruction required meticulous sequencing to preserve all landmarked features, particularly the copper pinnacle caps. Temporary shoring was installed to provide lateral stability to the pinnacles as portions of the masonry walls were removed and rebuilt. Upon completion, the pinnacles retained their exact historic profile and appearance (a requirement for an NYC Landmarked building) while benefiting from entirely new structure.
Ballroom Acoustic Isolation
Throughout its history, the Waldorf hosted significant social, political, and cultural events, with the ballroom at the center of many of these. However, the sound systems that support these events have evolved over the years. Modern sound systems generate much greater low-frequency energy than those envisioned when the building was designed.
Acoustic testing prior to hotel closure performed by Longman Lindsay demonstrated that low frequency sound energy could be audible in guest rooms as far as the 19th floor. For reference, the existing Ballroom floors include the 3rd through 7th floors; the new condominiums start on the 12th floor.
While this was manageable in a traditional hotel setting by moving guests to another room if there were complaints, its new use as condominiums required significantly improved acoustic performance for all spaces. Based on this study, Longman Lindsay suggested a solution that involved structurally isolating the ballroom from the remainder of the building. The design team developed a perimeter isolation system that effectively separated ballroom structural elements while preserving overall building stability. A new acoustic ceiling was also installed, however a structural isolated floor at the base of the ballroom was not required. This intervention required the majority of the finishes in the ballroom be removed and replaced.
Implementation of the structural isolation required cutting existing beam connections and introducing specially designed steel brackets with neoprene isolation pads. These new connections allowed the transfer of structural loads while interrupting vibration transmission paths. The connections and their components—including neoprene pads—were configured to provide support loads in the vertical direction in all locations and horizontal directions where required.
Construction required temporary shoring, selective slab removals, and installation of custom-fabricated steel brackets and isolation pads. Additional detailing at the finish surfaces by the architect ensured that architectural finishes would not inadvertently bridge isolation joints and compromise performance.
The completed ballroom retains its historic character while achieving dramatically improved acoustic isolation, allowing modern events to occur without disturbing hotel guests or condominium residents.
Working Above Metro-North Infrastructure
Perhaps the most unusual challenge of the project involved the building’s relationship with Metro-North Railroad infrastructure. Approximately 80% of the building sits directly above active rail tracks, and access below the ground floor structure was severely restricted for both investigation and construction activities.
Structural work that was required over rail spaces included slab repairs, elevator pit modifications, loading dock reconstruction, and repairs to Metro-North viaduct structures. Access often required specialized railroad safety training, overnight work windows, and escorts by Metro-North Railroad personnel.
The TYLin team, in collaboration with the architect and construction manager, adopted design strategies that minimized the need to perform work in the ceiling of the Metro-North space. In many cases, modifications were designed to be executed entirely from above. For example, the first-floor slab was comprised of stone concrete structural draped mesh slabs that were topped by cinder fill. In order to reinforce the existing slab for higher loads locally or to infill existing openings in the slab, the fill was removed and a new structural lightweight reinforced concrete slab was cast on top of the existing slabs using the original slabs as formwork. The steel framing supporting these slabs had excess capacity to support the increase in load from cinder to lightweight concrete and did not require reinforcement.
Elevator modernization presented particular challenges because new pits could not extend below the protective ceiling separating the building from rail spaces. Careful coordination among disciplines allowed the placement of the new elevators to be located in positions in the floor plan where elevator upgrades could proceed while avoiding significant impacts on railroad operations.
The loading dock area required extensive intervention. The new loading required to support compactors and modern trucks required an entirely new slab and additional beams to reinforce the area. The existing girders and their connections thankfully had additional capacity for these new loads. Additional beams were installed between the existing girders to support a new reinforced slab on metal deck capable of supporting the new load requirements of the equipment and truck wheel loading.
Just outside of the loading dock is the existing sidewalk of 49th street. While a typical sidewalk may sit on grade and be easily designed for higher design loads from modern vehicles, the structure supporting this sidewalk is part of the Metro-North Viaduct, supporting both sidewalk and the roadway of 49th street. Using this space as a modern loading dock not only required the analysis of the viaduct structure to support a modern truck being used for the dock, it also required design per modern NYCDOT Bridge and AASHTO codes. These loads included HL-93 design loads with a 1.33 Impact Factor, loading which far exceeds the weight of trucks and the code required loading of the 1920s when the viaduct was built. Overnight inspections of the viaduct stringers (beams) and their supporting girders and connections revealed substantial structural deterioration. While the team initially explored strengthening existing members, complete replacement of slabs and three of the four stringers was necessary for both cost and schedule. Metro-North requirements dictated that repairs rely on bolted rather than welded connections, influencing design solutions for these stringers as well. Metro-North design guide requirements limit the use of welding on the Viaduct as welded connections are fatigue prone details that reduce the service life of the structure especially in an area with cyclic vibrations.
MEP and Cogeneration
A cogeneration plant was included in the mechanical upgrades for the building renovation. This required very heavy equipment throughout the building necessitating slab replacement and beam reinforcement as well as many new penetrations for MEP routing. A new cooling tower was located in a setback location on the northeast corner of the building. Since the facade is landmarked and the cooling tower both required outside air intake and had to be hidden, the roof slab and the 19th floor slabs were locally removed to allow the cooling towers to be inserted into a new “well” of original brick masonry walls below the 20th level building setback at the northeast corner. The landmarked facade is permanently braced from the 18th to 20th levels, with steel column reinforcing and facade braces. A steel-framed platform above the eighteenth level was also added to support the three cooling towers, bearing on the existing column grid below. An access platform walkway was also built around the towers within the well.
The Waldorf Astoria redevelopment demonstrates the complexity and rewards of adaptive reuse in historic structures. The project required the design team to understand archaic structural systems, investigate undocumented modifications, repair extensive deterioration, and integrate modern performance requirements into a landmarked building.
From large-scale slab repairs and material testing programs to the reconstruction of the iconic pinnacles, acoustic isolation of the ballroom, and coordination with active rail infrastructure, every aspect of the project demanded creativity, technical expertise, collaboration, and a knowledge of the logistics of construction. The work transformed the building into a modern mixed-use development while preserving the historic character that has made the Waldorf Astoria a New York landmark for nearly a century.
Overall, the project illustrates a decade‑long effort combining historic investigation, modern analysis, and complex logistics to rehabilitate and adapt the landmarked Waldorf Astoria while preserving its architectural legacy. ■
Alastair C. Elliott is a Principal in the New York City office of TYLin’s Buildings Sector. His work has encompassed the design and project management for projects including new construction, renovation, and adaptive reuse for public and private clients. He also leads the sector’s Quality Management Program.
Victoria Ponce de Leon is a Vice President and Principal in the New York City office of TYLin’s Buildings Sector. Her work has encompassed the design and project management for a wide range of projects including new construction, renovation, and adaptive reuse for public and private clients.
