CivilEng, Vol. 6, Pages 44: Structural Evaluation with FWD of Asphalt Pavement with 30% RAP Reinforced with Fiberglass Geogrid in the Asphalt Layer
CivilEng doi: 10.3390/civileng6030044
Jaime R. Ramírez-Vargas
Sergio A. Zamora-Castro
Agustín L. Herrera-May
Rafael Melo-Santiago
Luis Carlos Sandoval Herazo
Domingo Pérez-Madrigal
Recycled asphalt pavement (RAP) can support traffic loads comparable to those of roads constructed with conventional materials. The structural evaluation of RAP is performed through the deflection generated by vehicles via recoverable deflection in the pavement layers. The deflection record is translated into a curve that geometrically interprets the behavior of the layers that make up the pavement. In this study, a falling weight deflectometer (FWD) was used to emulate transit loads and measure deflection in two models. Both contained 30% RAP, and one of them had fiberglass geogrid in the center of the asphalt layer. Through normalized maximum deflection (limit value based on constant stress), the structural index (SI), and the dynamic stiffness modulus (DSM), the structural behavior of the models under different load levels was evaluated. The pavement structure exhibited similarities in strength for both models subjected to impact. The presence of the geogrid reinforcement (Z1) showed structural index values ranging between 0.17 and 0.54, while the layer without geogrid (Z2) presented structural index values in a range of 0.23 to 0.78. In addition, the dynamic stiffness modulus presented a difference of 10 kN/mm between the maximums of the models in favor of reinforcement with glass fiber geogrid. Therefore, low structural index values are associated with the interaction between RAP and geogrid, highlighting this combination as an innovative and functional system for road surfaces, while the dynamic stiffness modulus indicates the stability and structural integrity of sustainable pavement, which has the potential to extend its lifespan.
