CivilEng, Vol. 6, Pages 48: Experimental Analysis of Steel–Concrete Bond Strength Under Varying Material and Geometric Parameters
CivilEng doi: 10.3390/civileng6030048
Gregor Trtnik
Jakob Šušteršič
Tomaž Hozjan
This study presents the outcomes of a comprehensive experimental investigation focused on the bond behavior between reinforcing steel bars and tremie concrete, assessed through standardized pull-out tests. The objective was to evaluate the influence of some key parameters: reinforcement bar diameter, concrete age (and associated compressive strength), steel fiber content, and a bentonite coating on rebar surfaces. Experiments were conducted under laboratory conditions according to relevant standards. Slip between the reinforcement and tremie concrete was measured using a sophisticated high-precision optical laser device, enabling accurate assessment of bond characteristics. A large, i.e., a statistically sufficient, number of specimens was tested, allowing the results to be analyzed using the ANOVA technique to determine the statistical significance of each parameter. The results show that, under most test conditions, the influence of the bentonite suspension coating on the bond strength was not statistically significant. Similarly, variations in the bar diameter and fiber content showed no statistically significant impact within the tested ranges. In contrast, concrete age (compressive strength) exhibited a statistically significant influence, confirming that concrete maturity is a dominant factor in bond development. The results contribute to a better understanding of the bond mechanisms in reinforced concrete and can assist in optimizing design strategies where bond performance is critical.
