CivilEng, Vol. 7, Pages 30: Experimental Investigation into the Strength and Deformation Characteristics of Silty Clay Stabilised with Hybrid Organic–Inorganic Binders
CivilEng doi: 10.3390/civileng7020030
Vassilios Aggelidis
Costas A. Anagnostopoulos
The aim of this research was to evaluate the efficacy of water-soluble epoxy resin (ER) in regard to stabilising clay soils, specifically for the design of column-type reinforcement in soft ground. An extensive laboratory program was conducted to assess the mechanical enhancement of a silty clay soil via ER, both as a standalone stabiliser and in combination with cement, bentonite, and sodium polyacrylate (PA). In addition, the study investigated the impacts of thermal stabilisation and electro-osmotic dewatering on resin–soil specimens. Specimens stabilised solely with ER exhibited poor strength development due to the inhibition of polymerisation by water. The addition of bentonite at low concentrations resulted in low early strength development and a moderate increase in the final strength. The use of cement provided the most significant strength gains, which were further enhanced by optimising the dosage of PA, although an excessive PA content significantly reduced the strength properties. In terms of physical treatments, thermal stabilisation at an optimal temperature of 60 °C for 24 h substantially improved the performance of ER. Electro-osmotic treatment accelerated the development of early strength but failed to provide appreciable strength improvement, and resulted in brittle behaviour and reduced toughness in the later stages (90–180 days). These findings offer critical guidelines for optimising mix designs and treatment protocols for geotechnical ground improvement projects.
