Construction Materials, Vol. 5, Pages 82: Experimental Investigation of Low Carbon Concrete Using Ground Seashell Powder as Filler and Partial Cement Replacement
Construction Materials doi: 10.3390/constrmater5040082
Ali Abbas
Anjana Kudukkan
The present experimental study was set up to examine the use of waste seashells (ground to powder form) to replace cement partially and as a filler material in concrete. Two distinct particle size ranges of seashell powder were adopted based on their intended function: 63–125 micron particles are used as a filler to enhance packing density, and 0–63 micron particles are used as a cement replacement to improve reactivity. Four concrete mixes, including a control mix, were designed, with ground seashell powder used to replace cement, both as a filler replacing 15% of the cement and additionally as finer seashell powder replacing 0, 15, and 30% of cement (labelled S0F15, S15F15, and S30F15, respectively). The seashells’ chemical, physical, and mineralogical properties were characterised using particle size analysis through sieving, X-ray diffraction (XRD), Scanning Electron microscopy (SEM), and pH test methods. Furthermore, the fresh properties of concrete, such as initial and final setting time, were studied. The hardened seashell-based concrete was subjected to direct compressive strength, bulk density, and modulus of elasticity analysis. The results showed that the 28-day compressive strength of concrete with seashells was moderately reduced by nearly 25% compared to the control mix. In the case of modulus of elasticity, the reductions were about 5%, 7% and 13% for mixes S0F15, S15F15 and S30F15, respectively, compared to the control mix CM. Finally, the carbon emission from concrete with 15% and 30% seashell powder content as cement replacement (plus 15% cement replaced with the powder acting as a filler in both cases) resulted in a notably lower carbon emission of 250 and 212 kg CO2 e/m3, respectively, compared to the control mix, with a reduction of approximately 24%. This is a sizable reduction in Global Warming Potential (GWP) value. Therefore, the study concluded that the investigated seashell powder in concrete could benefit an eco-friendly environment and conservation of natural resources.
