Construction Materials, Vol. 5, Pages 84: Assessing the Effects of Activator Formulation on Hardened Properties of Alkali-Activated Slag Mortars Using Ultrasound Pulse Velocity (UPV) Technique
Construction Materials doi: 10.3390/constrmater5040084
Victor M. E. Lima
Igor V. Fernandes
Diego H. Alves
Tiago M. S. Agra
Danilo J. da C. Barbosa
Eudes A. Rocha
Antonio A. Melo Neto
The UPV technique has been widely employed to predict the hardened properties of Portland cement mixtures. This article assesses the hardened properties of alkali-activated blast furnace slag mortars by comparing UPV measurements with compressive strength and dry density and calculating the dynamic modulus of elasticity from UPV results. The mixtures were prepared varying the type of activator (sodium metasilicate and sodium silicate), the content of Na2O in the activators (3.0, 4.5, 6.0, and 7.5%), and the water/binder ratio. The results showed that exponential models showed medium and high determination coefficients (R2), which explained the correlation between UPV and hardened properties. It was observed a limitation on the measurements of UPV, which did not surpass 4.4 km/s, which made it difficult to predict compressive strength value above 50 MPa. The dynamic modulus of elasticity calculated from UPV showed reliable results, even varying the Poisson’s coefficient between 0.15 and 0.25. Lastly, it was also observed that a correlation between the content of C-S-H and UPV suggested that this technique can also be used to predict the evolution of the hydration products in alkali-activated slag mixtures.
