Construction Materials, Vol. 6, Pages 18: Tire-Derived Aggregate as a Backfill Alternative for Retaining Walls: Nonlinear Time-History Analysis of Shake Table Tests
Construction Materials doi: 10.3390/constrmater6020018
Il-Sang Ahn
Lijuan Cheng
Tire-Derived Aggregate (TDA) is a recycled fill material made by cutting scrap tires into small pieces that satisfy the gradation requirements in ASTM D 6270. Since its introduction to civil engineering applications, TDA fill and TDA backfill have been successfully implemented in many projects. However, the dynamic behavior of the TDA backfill under significant earthquakes has not been substantially addressed. The present study used nonlinear time-history Finite Element Analysis (FEA) to analyze the dynamic behavior of a retaining wall with TDA backfill captured from the full-scale shake table test. Unlike typical soil failure observed in a similar retaining wall with conventional soil backfill, significant wall sliding occurred because lightweight TDA contributed to reducing the friction resistance of the wall footing. Therefore, the analysis required modeling capability of rigid body motion and impact loading from the separation between the wall stem and the backfill. With adequate friction models and softened contact models, the FEA generated the dynamic motion of the retaining wall that matched well with the measured responses, including the wall sliding. The friction model between the wall footing and soil was most critical in accurately reproducing wall sliding motion. It was determined to use different friction coefficients for the two different earthquakes used in the study in order to simplify the rate dependence of the coefficient. Also, the softened contact model generated more reasonable impact force by allowing overclosure and finite stiffness during impact. The FEA model and modeling technique in the present study can be used for the seismic design of various field-scale retaining walls with TDA backfill.
