Construction Materials, Vol. 6, Pages 31: Mass-Based Replacement of Natural Coarse Aggregate with Electric Arc Furnace Slag Aggregate in Ordinary Portland Cement Concrete
Construction Materials doi: 10.3390/constrmater6030031
Mohamad Ali-Ahmad
Christina El Sawda
Amenah AlFailakawi
Nourah AlKhaldi
Sarah AlMajed
Malak Sughayer
Nourah AlZuabi
This study investigates the effect of mass-based replacement of natural coarse aggregate with electric arc furnace (EAF) slag on the performance of ordinary Portland cement (OPC) concrete. Replacement levels of 0%, 30%, 50%, and 100% were examined, with particular attention to the volumetric changes induced by the higher density of EAF slag, which leads to an increase in paste volume. Fresh, mechanical, durability-related, and microstructural properties were evaluated. Results show a continuous reduction in workability with increasing slag content, despite the increase in paste volume, indicating the dominant influence of aggregate morphology on rheological behavior. Mechanical performance exhibited a non-linear response. Within the tested series, the 50% replacement mixture showed the highest mean compressive and splitting tensile strengths; however, the compressive strength difference relative to the control mixture remained small and within typical experimental scatter. In contrast, water absorption decreased progressively, reflecting improved matrix densification. However, this densification did not translate into enhanced mechanical performance, highlighting a decoupling between durability-related indicators and strength. A screening-level CO2 assessment further showed that reductions in aggregate-related emissions were offset by increased cement content associated with mass-based replacement. The results emphasize the importance of considering volumetric effects when interpreting the behavior and sustainability of slag-based concrete. Note: all strength comparisons are based on mean values from three-specimen sets without formal statistical testing and should be regarded as exploratory observations.
