Geotechnics, Vol. 6, Pages 22: Estimating Saturated Hydraulic Conductivity and Effective Net Capillary Drive Using a Portable Drip Infiltrometer Method
Geotechnics doi: 10.3390/geotechnics6010022
Wendy L. Puente-Castillo
Lorenzo Borselli
Damiano Sarocchi
Azalea J. Ortiz-Rodriguez
Dino Torri
Reliable field estimation of near-surface soil hydraulic parameters remains challenging, particularly in heterogeneous or stony soil environments. Conventional drip infiltrometers (DI) are widely used, but their field deployment may limit mobility and testing efficiency. This study presents a portable drip infiltrometer (PDI) methodology that enhances field applicability while reducing testing time without compromising parameter robustness. The approach enables estimation of saturated hydraulic conductivity (Ks), effective net capillary drive (G), and sorptivity (S) by integrating image-based analysis of ponded surface areas using the Portable Drip Infiltrometer Software (PDIS v1.5) with linear and non-linear infiltration formulations optimized through evolutionary algorithms. A total of 34 PDI field tests were conducted across two Mexican regions with contrasting climatic and soil conditions. In semi-arid environments, Ks ranged from 1.07 to 12.82 mm h−1 and G from 89.1 to 1999.99 mm, whereas in semi-warm sub-humid settings, Ks ranged from 30.68 to 117.68 mm h−1 and G from 2.65 to 121.64 mm. Results indicate that linear formulations perform adequately under relatively homogeneous conditions, while non-linear PDI formulations become necessary as surface structural complexity increases. The PDI–PDIS framework provides a rapid, repeatable, and physically grounded tool for parameterizing near-surface hydraulic processes in heterogeneous soils.
