Geotechnics, Vol. 6, Pages 23: Interpreting the Undrained Shear Strength of Soft Clays Using CPTu: Evaluation of Cone Bearing Factor (Nkt) and Related Practical Soil Parameters at Selected Sites in Western Java
Geotechnics doi: 10.3390/geotechnics6010023
Yuamar Imarrazan Basarah
Mirna Dwi Lestari Salamah
Masyhur Irsyam
Dedi Apriadi
Endra Susila
Sugeng Krisnanto
Juan Marvel
The geological complexity of Java Island, Indonesia, has resulted in the extensive distribution of very soft clay soils, posing significant challenges to geotechnical design and construction. A reliable estimation of the geotechnical properties of these soils is therefore essential to address these challenges and ensure the safety and sustainability of construction projects. The cone penetration test with pore pressure measurement (CPTu) is a reliable in situ test for soil characterization, providing a continuous shear strength profile. However, the determination of a representative cone bearing factor (Nkt) to estimate undrained shear strength (Su) is critical for geotechnical design. Although several studies on CPTu have been conducted in Indonesia, there has been a lack of emphasis on establishing Nkt values for local soft, high-plasticity clays in Indonesia. This study aims to fill this gap in the literature by proposing updated correlations for Nkt specific to the soft, high-plasticity clays of Java, Indonesia, derived from the statistical analysis of combined field and laboratory data obtained from two representative sites in Western Java. These sites correspond to a coastal plain deposit in Central-North Jakarta and an alluvial deposit in Gedebage, Bandung. A comprehensive database was compiled, consisting of 20 CPTu boreholes, 84 depth points of vane shear test (VST), 29 samples of consolidated undrained (CU) triaxial tests, 26 samples of unconsolidated undrained (UU) triaxial tests, and 18 standard penetration test (SPT) boreholes. The results indicate that the representative Nkt value for these soft, high-plasticity clays in the investigated sites in Western Java ranges from 14 to 16. A refined empirical correlation between Nkt and the pore pressure ratio (Bq) is proposed, demonstrating consistent trends with recent data. Additionally, a reasonable correlation between the undrained modulus (Eu) and undrained shear strength of Eu = 276–323 Su was identified, enabling the derivation of a continuous profile of the undrained modulus from CPTu data. This study also further highlighted the absence of significant relationships between Nkt and other parameters such as OCR, PI, and NSPT. These findings provide practical insight and a regionally calibrated reference that can be useful for engineers working in similar soft, high-plasticity clay environments with characteristics comparable to the investigated sites in Western Java.
