Geotechnics, Vol. 6, Pages 40: Assessment of Density-Dependent Hydro-Collapse Mechanisms in Fine-Grained Geomaterials: A Multi-Axial Stress Analysis
Geotechnics doi: 10.3390/geotechnics6020040
Juan Carlos Ruge
Carlos J. Slebi-Acevedo
Volumetric collapse, a critical phenomenon in clayey soils, is characterized by a sudden reduction in volume when subjected to wetting under a specific effective vertical stress. This behavior is primarily caused by the breakdown of cementing bonds between particles in the soil’s interstitial spaces. Our study, which examines the impact of unit weight and wetting on the collapse potential of clayey soils under various stress conditions, has practical implications for geotechnical engineers. We evaluated three-unit weights spanning from loose to compacted states and assessed collapse behavior at various stress levels. Even in the observations of the microstructure under a scanning electron microscope, which corroborated the images, the pathology is evident. The results demonstrate an explicit dependency between unit weight and collapsibility. Statistical analysis revealed that unit weight was the predominant factor influencing the outcomes, with the magnitude of applied stress being identified as a secondary yet notable determinant. Furthermore, the non-linear interactions, as elucidated through ANOVA and Tukey’s HSD tests, serve as instrumental methodologies in this analytical framework. The findings underscore a significant correlation between applied stress and collapse potential, underscoring the crucial role of soil densification in mitigating the risks associated with collapse phenomena.
