Geotechnics, Vol. 6, Pages 55: A Critical Review of the Physical Properties and Geotechnical Behaviors of Tailing Materials
Geotechnics doi: 10.3390/geotechnics6020055
Wenpeng Liu
Shengli Wang
Junbiao He
Qingyun Xu
Nestor Tupa
Di Wang
Nan Zhang
The stability of tailings dams is governed predominantly by the physical properties and geotechnical behavior of their primary construction material—tailings. Consequently, a systematic understanding of these characteristics is of great significance for the rational design and long-term stable operation of tailings dams. This review focuses on the physical properties and geotechnical behavior observed in different types of tailings. In terms of physical properties, the particle size distribution exhibits a pronounced hydraulic classification characteristic within the impoundment, consisting predominantly of silt-sized particles and displaying an overall trend toward finer gradation. The mineralogical and chemical composition is dominated by quartz, hematite, and silicates. However, significant spatial variability exists both between different tailings types and across distinct zones within the same tailings pond. Regarding geotechnical behavior, the permeability of tailings is governed by a fines content threshold: below this threshold, permeability decreases with increasing fines content, while beyond it, the permeability stabilizes. When studying consolidation and compression behavior using slurry specimens, the compression curves exhibit nonlinear characteristics, primarily described by the modified Gibson theory. The shear behavior of tailings is significantly influenced by confining pressure, drainage conditions, anisotropy and stress paths. The presence of transitional behavior leads to the critical state line determined based on a single sampling method erroneously assessing the dilation/cosntraction characteristics of in situ tailings, thereby affecting the assessment of liquefaction risk. Future research should focus on the seepage, consolidation and shear properties of clayey fine-grained tailings and unsaturated tailings, and aim to elucidate the key controlling factors of transitional behavior to enhance the reliability of tailings dam stability assessments.
