Infrastructures, Vol. 11, Pages 265: Human-Centered Optimization of Expressway Interchange Guide-Sign Infrastructure in Complex Road Networks: Evidence from Visual Behavior, Physiological Responses, and Driving Simulation
Infrastructures doi: 10.3390/infrastructures11080265
Yanshuang Zhi
Shuzhen Lou
Hongfu Wu
Yingying Luo
Yanqun Yang
Expressway interchange guide signs must support rapid route decisions under limited viewing time, high information load, and potential vehicle occlusion. This study developed a human-centered framework for optimizing guide-sign information and presentation in complex expressway networks by integrating an on-road field experiment, driving simulation, eye-movement measures, physiological responses, and driving behavior. The field experiment involved ten drivers unfamiliar with the Fuzhou expressway network and yielded 119 valid sign-reading episodes. A separate simulation experiment with 60 licensed drivers examined character heights of 55, 65, and 75 cm and roadside, median-side, and dual-side installation under three ordinal traffic background conditions. Drivers generally initiated visual search in the upper-left region of sign panels and focused on route-relevant place names and directional arrows. Descriptive observations suggested that usable control-point information could support route inference when the destination was absent, whereas the absence of both destination and usable control-point information was accompanied by more sustained deceleration and more dispersed visual search. Effective viewing distance increased across the tested character-height conditions. At a design speed of 120 km/h and an assumed recognition time of 2.6 s, the required viewing distance was approximately 86.7 m. The mean viewing distance for the 55 cm condition was below this requirement, whereas the 65 and 75 cm conditions exceeded it. The findings were applied to Xiuzhai Interchange. In a dynamic screen-based route-choice test, 24 of 25 participants made acceptable choices. Overall, guide signs in complex networks should be designed as coordinated information systems integrating control-point hierarchy, information continuity, character height, and installation position.
