Infrastructures, Vol. 11, Pages 281: Synergistic Enhancement of Foamed Concrete Performance with Fibers and Additives Under Low-Temperature Environments and Mix Proportion Optimization
Infrastructures doi: 10.3390/infrastructures11080281
Yufeng Xian
Yaning Zhang
Zunqing Liu
Haiwei Xie
Yifei Wang
To address the technical challenges of hydration retardation and low early strength of foamed concrete in low-temperature environments of cold regions, this study investigated the effects of low-temperature curing (cycling between −5 °C and 5 °C) on the mechanical properties and microstructure of foamed concrete. Single-factor experiments were conducted to explore the effects of triethanolamine (TEA), urea, and polypropylene fibers (PPF) on the mechanical performance of foamed concrete. A response surface methodology (RSM) was employed to establish regression models between the dosages of each component and the compressive strength (CS), thereby determining the optimal mix proportion under low-temperature curing. The experimental results indicate that increasing the urea dosage leads to an increase in the flowability of foamed concrete, and the effects of the three types of admixtures on the CS all exhibit a non-linear characteristic that first increases and then decreases. The significance of the three factors on the CS of the material follows the order: TEA > PPF > urea. The obtained optimal mix proportion is 0.052% TEA, 1.08% urea, and 0.194% PPF, yielding 3, 7, and 28 d CS of 1.088 MPa, 1.342 MPa, and 2.301 MPa, respectively. Microstructural analysis via SEM observations and XRD analysis suggest that the admixtures effectively compensate for the hydration retardation induced by low temperatures, promoting the abundant generation of needle-like ettringite (AFt) and C-S-H gels that interweave into a dense network, thereby achieving higher strength. This study provides a theoretical basis and technical support for the low-temperature construction of foamed concrete subgrades in cold regions.
