Infrastructures, Vol. 11, Pages 282: Moisture Migration and Variation in Pile Shaft Resistance During Hydration-Heat-Induced Thawing–Refreezing Around Cast-in-Place Piles in Permafrost
Infrastructures doi: 10.3390/infrastructures11080282
Zhilong Zhang
Tengbo Yu
Xuejun Liu
Jiyang Zhang
The shaft resistance of cast-in-place piles in permafrost regions is commonly estimated using the initial moisture content and frozen-soil strength parameters obtained during site investigation. However, concrete hydration heat disturbs the temperature field of the surrounding frozen soil. During thawing and subsequent refreezing, this disturbance induces unfrozen-water migration and moisture redistribution. The resulting changes in the frozen pile–soil interface may cause the measured shaft resistance to deviate from the initial design estimate. In this study, laboratory direct shear tests and engineering-oriented reduced-scale pile–soil segment tests were conducted. The effects of initial moisture content and soil stratification on interface shear strength, the surrounding temperature field, and the post-test moisture distribution were investigated. Vertical pile compression tests were also performed to evaluate changes in pile shaft resistance. The main results are as follows. (1) The shear strength of the concrete–frozen-soil interface varied nonlinearly with moisture content. It increased initially and then decreased, reaching its maximum at a moisture content of 30%. (2) The temperature rise in the surrounding frozen soil was jointly controlled by soil stratification and initial moisture content. Higher moisture contents produced smaller peak temperature rises. In the near-pile region, the maximum difference in peak temperature among soil layers with different moisture contents was approximately 10.8%. (3) During thawing and refreezing, moisture migration was jointly affected by the temperature gradient and the moisture conditions of different soil layers. Unfrozen water migrated toward colder regions or lower-moisture soil layers under temperature gradients, capillary effects, and freezing suction, resulting in near-pile moisture depletion and localized moisture enrichment. For the Group A model, the initial-state estimate underestimated the measured peak shaft resistance by 12.45%. In contrast, for the layered B1 model, the initial-state estimate overestimated the measured peak shaft resistance by 20.58%. (4) A preliminary lumped equivalent coefficient, keq, was introduced to establish a relationship between moisture content and local equivalent interface resistance. After the measured post-test near-pile moisture distributions were incorporated into the calculation, the relative deviation decreased from 12.45% to 7.36% for Group A and from 20.58% to 9.66% for B1.
