Infrastructures, Vol. 11, Pages 285: Interlayer Shear Response of Asphalt Bridge Deck Pavements Under Thermo-Mechanical Coupling and Moving Braking Loads
Infrastructures doi: 10.3390/infrastructures11080285
Xuan Zhu
Zhi Li
Xiangyu Lei
Hailin Wang
Weiwei Lu
Dingling Yang
Hongyu Ren
Yuxi He
Weiguo Wu
Peng Chen
Asphalt bridge deck pavements are highly susceptible to rutting, shoving, and interlayer slippage under high-temperature traffic conditions, where interlayer shear stress plays a decisive role. To clarify the coupled effects of thermal gradients and moving loads, this study developed a sequential three-dimensional thermo-mechanical finite element model for a double-layer pavement in Zhongshan, China. Field-recorded air temperature, solar radiation, sunshine duration, and wind speed were used to define transient thermal boundaries. The calculated temperature field was then transferred to a fully bonded moving-load model with dual rectangular contact areas and braking-induced longitudinal traction. Axle load, roadway slope, braking coefficient, and the thicknesses of the SMA-13 and AC-20 layers were varied. The predicted temperature fluctuation attenuated and the peak time was delayed with depth. The pavement surface reached 58.95 °C at 13:00, whereas the bottom of the asphalt overlay reached 46.99 °C at 17:00. Under the adopted 14:00 near-peak summer condition, increasing axle load amplified the overall response and raised the maximum asphalt-layer shear response from 0.172 to 0.223 Mpa. Roadway slope mainly affected traffic-direction stress transfer. Increasing the braking coefficient from 0 to 0.7 increased longitudinal shear response from 57.9 to 161.2 kPa in the asphalt layers and from 56.4 to 112.6 kPa near the AC-20/concrete interface. Increasing SMA-13 thickness reduced thermal and mechanical demand in the underlying layers, whereas increasing AC-20 thickness reduced the response near the concrete deck but shifted part of the tensile and shear demand toward the upper asphalt layer.
