Infrastructures, Vol. 11, Pages 294: Effect of Arundo donax L.-Derived Lignin on the Chemo-Mechanical and Oxidative Ageing Behaviour of Bitumen
Infrastructures doi: 10.3390/infrastructures11090294
Rui Micaelo
Margarida Sá da Costa
Bernardo Rodrigues
Catarina Leal
Ana Luísa Fernando
This study investigates the effect of Arundodonax L.-derived lignin on the rheological behaviour, mechanical performance and oxidative ageing resistance of bitumen. Arundo donax is a fast-growing invasive grass with high lignin content, representing a promising sustainable biomass source for bitumen modification. Lignin was extracted via the Acid Detergent Lignin method, yielding a fine powder (50–300 μm). The incorporation of 6 wt% lignin into a 35/50 paving-grade bitumen induced significant changes in binder behaviour. Infrared spectroscopy (FTIR) confirmed the polyaromatic and oxygenated nature of lignin and indicated that its interaction with bitumen is primarily physical, involving polar intermolecular interactions rather than chemical bonding. Lignin modification significantly increased stiffness, elasticity, and rutting resistance, as evidenced by higher softening point, complex modulus, and recovery after creep loading. Furthermore, FTIR analysis confirmed a reduced susceptibility to oxidative ageing, demonstrated by lower increases in carbonyl and sulfoxide indexes after ageing. This suggests distinct antioxidant activity associated with the phenolic structures of lignin. Despite these benefits, severe long-term ageing led to a marked reduction in fatigue life, ductility, low-temperature cracking resistance, and adhesive properties. Overall, these results demonstrate that Arundo donax-derived lignin is a promising sustainable modifier for bitumen, though optimisation of the dosage and blending conditions is necessary to balance durability against long-term fracture performance.
