Beyond the Finish
On a job site, most intumescent fire protection looks like paint to the untrained eye. It is applied much like an architectural coating, but its purpose is far more critical. Intumescent fire-resistive material (IFRM) is a high-performance life-safety system designed to protect structural steel during a fire. Most people who occupy the finished building will never notice it or think about the role it plays—until the moment it is needed. IFRM also may only have one opportunity to perform: during a fire. And when that moment comes, there is no room for uncertainty. The general contractor, steel fabricator, fire protection applicator, and inspector may all be asked the same critical question: Can you prove it was installed correctly?
That question is where the real risk in intumescent coatings lives—not in whether a project used shop-applied or field-applied product, but in whether the process around either choice was controlled, documented, and coordinated. Both methods have succeeded, and both methods have failed. The failures were rarely about the coating chemistry, however, and stemmed more from errors in the application of the material or the substrate into which the coating was applied. Common errors occur due to incorrect surface preparation, primer failure, application environment, transportation and handling damage, and mechanical damage, all of which are a part of the application process. When the schedule is compressed, short cuts happen.
Intumescent Basics
Intumescent coatings protect structural steel by reacting to rapid rise in heat during a fire event; typically this exposure in ASTM E119/UL 263 is a gradual rise in temperature given fire loading in a commercial building. UL 1709 fire exposure is often a rapid rise in heat and sometimes a direct flame exposure given the fire loading of oil and gas.
Intumescent coatings work as they expand 20 to 40 times their applied thickness when exposed to a rise in heat and form an insulated char, slowing heat transfer and heat sync and keeping steel below its critical failure temperature.
This allows enough time for life safety measures to activate, people to evacuate and maintain a protected egress, and ultimately prevent structural collapse. That performance depends entirely on applied thickness matching a manufacturer’s tested, third party-listed design—ASTM E119/UL 263 for standard fire ratings, or UL 1709 for hydrocarbon-type exposures.
It is always wise to consult with the manufacturer to ensure applied thicknesses are verified and the third-party design is being followed. Some examples are compliance with flute treatment, applying the right primer (chemistry type or even specifically called out in the design), and, for UL 1709, you are following the application thicknesses and applicable protection thickness for Jet Fire and Cryogenic exposure. In many cases, additional thickness will be added as a sacrificial layer to protect the material applied for the UL 1709 fire exposure. Remember, third-party listed designs are prescriptive requirements that reflect the exact conditions and materials evaluated during fire testing. Following these designs to the “T” is critical to maintaining compliance and ensuring the fire protection system performs as tested and intended.
Why Fireproofing Isn’t a “Finish” Item
If fire protection is treated as a finish trade, finish-trade risk tolerances become an issue: minor thickness variance, cosmetic touch-up, and a “close enough” mentality. Treat it as the life-safety system it legally and functionally is, and the standard for acceptable variance changes completely. That distinction should drive every decision a contractor makes about how, where, and when the coating goes on. It also comes down to how each type of work gets judged. A finish item is evaluated on how it looks; fireproofing is evaluated on whether it performs—and there’s no visual way to tell the difference. A coat that looks flawless can be under the required thickness and fail. A rougher-looking coat applied to the correct dry film thickness will perform exactly as designed. Paint that’s a little thin or slightly off-spec is a punch-list item: cosmetic, low stakes, fixable later.
Fire protection out of system compliance (not applying the prescribed dry-film thickness (DFT)) is a life-safety risk that stays invisible until it is needed in a catastrophic event—and by then it is usually enclosed behind drywall, a ceiling, and cladding, where no one can tell whether it is compliant. The only proof at that point is the documentation captured during application and inspection process: Blast profile, primer thickness, IFRM DFT measurements, and environmental conditions recorded in real time. That’s the real dividing line between a finish trade and a life-safety system—finish work is judged by appearance, and fireproofing must be verified as correct soon after installation.
The Real Trade-Off: Shop vs. Field
Shop-applied IFRM, which is typically epoxy based intumescent material, is installed in a controlled environment by a qualified fire protection contractor. In shop conditions, the application of IFRM is under consistent environmental conditions where temperature and humidity are monitored closely and adjusted to maintain quality. Other critical items, such as surface-prep conditions and primer, are also closely monitored as steel is still not erected, and the workspace is ideal for working heights without any access difficulties. Because of these conditions, shop work tends to produce the best QA/QC and finished product. However, there is still a field aspect of shop applied fire protection that needs to be recognized: handling, transportation, erection, flute treatment, field touch up, and field-applied IFRM block-outs at steel connections. Even after steel erection, every one of these steps inherits a chance for damage. System compliance does not occur until block-outs, touch up and flute treatment are completed.
Field-applied IFRM avoids the transportation risk entirely and gives more flexibility to absorb late design changes. However, the steel is fully exposed to the job site: weather, humidity, dust, wind-driven overspray variability, and access constraints from lifts, booms, and scaffolding. Field work is also sequenced behind other trades—commonly concrete pours—which means fireproofing inherits every upstream schedule slip as a compressed working window.
Where Liability Actually Shows Up
In the author’s experience, generally the root cause of failures falls into one (or more) categories—adhesion failure, incorrect DFTs, and damage. These typical root causes create real exposure to all parties, but every one of them is preventable through process discipline:
  • Adhesion failure/delamination—This failure almost always traced to inadequate surface prep, an incompatible or over applied primer, or encased moisture. A minimum blast profile should be followed (per the manufacturer’s recommendations, for a minimum SP 2 or 6, depending on IFRM utilized), the applicator should also ensure that the primer is applied to the correct DFT as recommended by the manufacturer’s technical application guide. Any deviance or failure to meet these requirements could result in system failure. The proper application environment is also critical for the curing of both the primer and IFRM. Care should be taken to ensure humidity and temperature at the time of application and curing fall within the manufacturer’s recommendations.
  • Incorrect dry film thickness (DFT)—The single biggest driver of fire-resistance-rating inspection failures is caused by poor spray control or absent QA/QC. Continuous DFT inspection during application, not spot checks afterward, is the only real mitigation. It is also critical to have the third-party inspections take place where the application happens. For example, if it is a shop-applied IFRM, the inspection for 85-90% of the surface area coated with IFRM should take place in the shop. Field inspections should only occur on the field applied areas (block-outs), not the surface areas applied with intumescent in the shop.
  • Coating Failure—Epoxy intumescent coatings are far less forgiving of application variables than SFRM: most defects—cracking, alligatoring, blistering, pinholing, sagging, delamination, amine blush, and under-cure—trace back to excess DFT per pass, incorrect mix ratio or induction time, contamination or moisture at the surface, or work performed outside the re-coat window and temperature/dew point limits. Chalking and telegraphing stem instead from UV exposure without a protective topcoat and inadequate surface prep, while the real consequence of any of these is reduced char integrity that can jeopardize UL/FM fire-test compliance.
  • Mechanical damage—This damage is most often caused by trade traffic, handling, and transportation. This is the risk shop-applied systems carry that field-applied systems don’t, and it needs a real protection plan, not an assumption that “someone will touch it up.” The fire proofing contractor should be responsible for the protection plan and the trade(s) who causes the damage will coordinate with the fireproofing contractor to remediate the damage.
  • Moisture intrusion—A missing or failed topcoat, and/or poor detailing at terminations can cause moisture intrusion. Most epoxy IFRM manufacturers require or highly recommend exterior topcoat and correct detailing at every termination point. A chamfered edge, butt-joint, and top-coat is non-negotiable on exterior work.
Documentation Is Your Liability Protection
Every one of those failure modes is defensible—or indefensible—based on what’s in the inspection record. Shop-applied work should be inspected in the shop, where it’s applied; field-applied work should be inspected in the field. For every application, the documentation package which is created by the steel fabricator and expanded by the fireproofing contractor, should capture piece marks, blast profile, primer adhesion and DFT, IFRM DFT, top-coat adhesion and DFT, environmental conditions, and surface temperatures at the time of application.
UL 263 work typically follows AWCI Technical Manual 12B or IBC Chapters 7 and 17 for inspection protocol; UL 1709 work typically follows SSPC-PA2 or ISO 19840, depending on what the owner has adopted as its standard of practice. Get agreement in writing from all parties—fabricator, applicator, inspector, and owner’s representative—on which inspection standard applies and who documents what, before work starts. That single conversation, earlier, resolves more disputes than any amount of after-the-fact finger-pointing once steel is already erected.
Schedule Is a Risk Multiplier, not a Side Issue
Fire protection decisions ripple through the entire construction schedule. Shop-applied work front-loads time before erection and adds additional transportation and storage logistics. Field-applied work stacks behind concrete pours, needs weather buffers, and competes with other trades partners for access. On either path, the mitigation is the same: make the IFRM decision early, define scope boundaries—especially at the shop/field interface where block-outs, flute treatment, and connections have to be closed out—and put fireproofing coordination on the agenda in preconstruction meetings rather than treating it as an afterthought.
The Takeaways
Lifecycle cost and liability exposure on intumescent coatings are driven far more by process control than by which application method or coating chemistry gets specified. Shop-applied and field-applied systems, executed correctly, deliver the fire resistance rating called for in the design. Executed carelessly, and the outcome could be a member with a documented third party listed assembly that may not actually be protected to the specified thickness—a gap that doesn’t show up until a fire event, or an inspection, exposes it.
Those who manage this exposure successfully share a few key habits. They verify that the specified W/D (Hp/A) ratio, DFT, and listed assembly match the applied system rather than assuming spec compliance from a submittal. They require surface prep, thickness verification, and inspection hold points to be locked in before work starts, not added after the fact. They demand continuous documentation—DFT readings, mix records, environmental conditions at time of application—as the basis for sign-off, rather than accepting a closeout package assembled after the fact. And they hold fireproofing contractor selection to the same standard as any other life-safety trade: the system and applicator need to be capable of achieving the rated assembly as designed, not simply the easiest or cheapest to install. ■
Cabot Wilkinson is Vice President of Specialty Projects at Rolling Plains Construction, where he leads passive fire protection scope across advanced manufacturing, semiconductor, data center, and commercial construction markets. He holds a B.S. in Fire Protection and Safety Technology from Oklahoma State University and has spent more than 20 years in the passive fire protection industry, spanning both manufacturing and contracting. This article is adapted from his AIA-accredited NASCC 2026 session, “Beyond the Finish: Fire Protection Strategies with Intumescent Coatings.”
Source link
