CivilEng, Vol. 7, Pages 44: Study on Parameter Optimization of a Multi-Mass Pendulum for a Wind-Induced Vibration Control System
CivilEng doi: 10.3390/civileng7030044
Han Wang
Zuohua Li
Dan Han
Jun Teng
The tuned mass damper (TMD) exhibits good performance in suppressing wind-induced vibrations of high-rise structures. However, a single TMD has a limited control bandwidth and poor robustness. The multiple-pendulum tuned mass damper (MPTMD) offers advantages, such as a wider control bandwidth, stronger robustness, and a simple structural configuration, while its working frequency can be easily adjusted by varying the pendulum lengths. With two optimization objectives, namely displacement and acceleration, this study derives the displacement and acceleration dynamic amplification factors of the primary structure equipped with the MPTMD under external excitation and examines the interrelationships among the optimal parameters and their underlying mechanisms. The accuracy of the proposed optimization method and the effectiveness of the MPTMD are validated by fitting the theoretically derived optimal parameter curves with results from numerical simulations. Finally, the control performance of MPTMD and TMD is compared through a numerical example subjected to realistic wind load excitations, verifying the control effectiveness of MPTMD. Nevertheless, several limitations should be acknowledged. The present optimization is based on a single-degree-of-freedom (SDOF) primary structure and targets only the first translational mode; the effects of higher modes and multi-degree-of-freedom (MDOF) coupling are not considered. Additionally, the wind load is represented by a synthetic time history with a fixed return period, and uncertainties in real wind fields are not fully addressed. Future work should extend the proposed method to multi-modal control, nonlinear behavior, and experimental validation.
